Further information on wiki formatting can be found at DokuWiki syntax
Our wiki depends on the cooperation of all club members!
Everybody is invited to contribute his knowledge! - And I'm quite sure that each of us knows something that somebody else can use sometime
But to avoid an unmanageable proliferation we should consider a few things.
All pages you see in the Wiki can be changed, added, edited.
If you find an error somewhere, if you can/would like to describe a point better/precisely or if you want to describe a new topic, then you can simply switch to edit mode (button at the edge of each page).
In edit mode you will see the text of the page with all formatting information and can make changes.
The edit mode has some buttons at the top of the page to format the text and insert links. These functions are described below.
If you are unsure, or just want to try something, you can also try it on the test page.
Important to keep structure in the wiki is the following:
New, self-contained topics should also be described on new pages! Please do not mix different topics on one page! If we 'keep order' here, the topics can be reused in other places.
For example, the page 'Correctly making crimped cable connections' could be linked to the pages 'Electrics / Electronics' and 'Lighting'. If the topic is somewhere in the page 'Electrics / Electronics', it is lost for the page 'Lighting' or has to be added there again.
It would also be nice if all pages had a uniform (or at least similar) structure:
The page Rover-Motor could serve as an example
The easiest way to create new pages is to first create an internal link to the new (not yet existing) page.
This sounds a bit strange, but it is actually the easiest way
So:
You have now created a link to a not yet existing page. The link should now appear red in the original page.
If the link is displayed in blue, then there is already a page with the name you have chosen!
And exactly here it becomes clear what to consider with the page names:
The wiki framework identifies the new page by the text you enter as name! So please be as accurate as possible when naming new pages e.g: “Ford T9 transmission to Rover K-Series engine” and not just “transmission to engine”. This way another user has the chance to create the page “Caterham 6-Speed Transmission to Ford Kent Motor” without getting wrong links.
If the link creation worked (red) you can simply click on the new link and fill the new page with content.
You can simply write normal text on the page.
But please note the following:
For our 'small Wiki' a few formatting options should be sufficient.
The easiest way to print in bold is to highlight the text and press the “Bold Text” key. In the written text bold passages are shown in two stars (**).
| What you write | How it is presented to the reader |
| this text is **partly bold** printed | this text is partly bold printed |
Italics can be printed most easily by marking the text and pressing the ”italic text“ key. In the written text, passages in italics are represented by two slashes (//).
| this text is //partly italic// printed | this text is partly italic printed |
Hierarchical enumerations can be made by using the asterisk (*) at the beginning of the line.<br/> Deeper levels of the enumeration can be realized by several stars (, *).
* One
Numbering can be done by using the 'hash' (#) at the beginning of the line.<br/> Deeper levels of numbering can be realized by several rhombuses (##, ###).<br/> Please DO NOT include numbering in the names of pages (because of the reuse mentioned above).<br/>
# One<br/> # Two<br/> ## Two-One<br/> ## Two-Two<br/> ### Two-Two-One<br/> # Three<br/> </html>
- One
Inserting images into the text is done in a similar way to creating new pages.
Different types of links can be used. For each type there is a corresponding pushbutton in editing.
Internal links refer to other pages of our Wiki.
By pressing the 'Internal Link' button, Wiki inserts a four square brackets and the text “Link Text” into the page.<br/> The text “Link text” must be replaced with the name of a Wiki page.
| the text [[weber double carburettor]] is a wiki-internal link | the text weber_double carburettor is a wiki-internal link |
Internal links are displayed red if the linked page does not yet exist.
External links refer to (foreign) Internet pages.
By pressing the 'External link' button, Wiki inserts two square brackets and the text "http://www.example.com Link text" into the page. The text "http://www.example.com" must be replaced by the path of the Internet page.<br/> The text “Link text” should be replaced by a meaningful name.
| [[http://wiki.caterhamcar.club/images/Servicehefte/Lotus_7_assembly_guide.pdf|Caterham Seven 1600 BDR 1986(English)] [[http://wiki.caterhamcar.club/images/Servicehefte/Lotus_7_assembly_guide.pdf | |
In the description of file links, the language of the file should be specified (if possible)
If there is anything missing or if you have any questions, just get in touch with me (mailto:webmaster@caterhamcar.club)!
Otherwise: Have fun with it and … be brave!
